Introduzione
Dans ce tutoriel, vous allez apprendre à remplacer la batterie de votre Samsung Galaxy Tab 10.1. Avoir une batterie défaillante ou non fonctionnelle peut être frustrant. Il y a encore quelques pré-requis dont nous devons nous occuper d'abord !
Cosa ti serve
Placez le bas de la tablette vers vous.
Retirez les deux vis de 4,1 mm près du port de charge avec un tournevis Tri-Wing.
Retournez le clapet de retenue des connecteurs ZIF qui maintiennent les trois larges nappes.
Retirez avec précaution les trois nappes de leur prise sur la carte mère.
Pour rassembler votre appareil, suivez les instructions dans le sens inverse.
Altre 61 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
20 Commenti
Those 3 plastic bands with connectors at the end are a really poor design and a drag to put back on correctly : there's a little white line drawn on each one that needs to be aligned with a line drawn on the socket itself. This means you really have to push them back in (with a little platic tool for example). If not you can have a non functioning screen or no touch detection.
What would be the correct battery that is suitable for the Tab proT520? I can't find any reference to this particular models battery..
good jobs man
Nice tutorials, thank you! I want to ask you about exactly battery. Where is it better to order it/ I mean, if i order it online? I live in Europe and know some stores of hardware, such as hardware.nu and so on but also i know such stores as Amazon and eBay also Aliexpress..Tell me where is quaity is the best?
