Salta al contenuto principale
Removinging Panasonic DVD-RV31 Player Rear Panel
Cosa ti serve
  1. Removinging Panasonic DVD-RV31 Player Rear Panel, Outer Case: passo 1, immagine 1 di 2 Removinging Panasonic DVD-RV31 Player Rear Panel, Outer Case: passo 1, immagine 2 di 2
    • Remove the three screws running along the back edge of case cover.
    • Remove the two screws from each side of the case cover.
  2. Removinging Panasonic DVD-RV31 Player Rear Panel: passo 2, immagine 1 di 1
    • Grab edges of the cover with your hands. Pull outward slightly, then straight up.
  3. Removinging Panasonic DVD-RV31 Player Rear Panel, Rear Panel: passo 3, immagine 1 di 2 Removinging Panasonic DVD-RV31 Player Rear Panel, Rear Panel: passo 3, immagine 2 di 2
    • Be sure case cover has been removed prior to back panel removal.
    • Remove 5 screws from panel, as shown.
  4. Removinging Panasonic DVD-RV31 Player Rear Panel: passo 4, immagine 1 di 2 Removinging Panasonic DVD-RV31 Player Rear Panel: passo 4, immagine 2 di 2
    • Use flat-head screwdriver to push in square tabs, located on each side of the back panel.
    • Use caution, the edges are sharp.
Conclusione
Kevin
Membro da: 04/26/11
375 Reputazione
8 Guide realizzate
Cal Poly, Team 18-20, Garner Spring 2011 Membro di Cal Poly, Team 18-20, Garner Spring 2011
CPSU-GARNER-S11S18G20
4 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 2,281
