Introduzione
Outline what you are going to teach someone how to do.
Parti
Nessuna parte richiesta.
  1. Remove 3 screws running along back edge of case cover.
    • Remove 3 screws running along back edge of case cover.
    • Remove 2 screws from each side of case cover.
  2. Grab edges of cover, pull outward slightly, and pull straight up.
    • Grab edges of cover, pull outward slightly, and pull straight up.
    • Be sure case cover has been removed prior to back panel removal.
    • Remove 5 screws from panel, as shown.
    • Use flat-head screwdriver to push in square tabs, located on each side of the back panel.
    • Use caution, the edges are sharp.
Conclusione
Kevin
Membro da: 26/04/2011
351 Reputazione
8 Guide realizzate
Cal Poly, Team 18-20, Garner Spring 2011 Membro di Cal Poly, Team 18-20, Garner Spring 2011
CPSU-GARNER-S11S18G20
4 Membri
11 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 8
Tutti i Tempi: 2,001
