Salta al contenuto principale
Removing the lid
Cosa ti serve
  1. Removing the lid, Ensure JuiceBox is de-energized: passo 1, immagine 1 di 1
    • Ensure the AC supply to the JuiceBox is disconnected before continuing. If the unit is plug-in, this is easy to simply ensure the box is unplugged from the NEMA 14-50 wall outlet. If hardwired, high-voltage safety training is recommended.
  2. Removing the lid, Remove lid screws: passo 2, immagine 1 di 1
    • Place JuiceBox on a horizontal surface for easiest work.
    • Three different types of screws were used throughout the history of JuiceBox versions.
    • Philips #2 (silver screw)
    • 2.5mm hex (rusted black screw)
    • T20h security Torx (black screw)
    • If you have a 2.5mm hex screw, be extremely careful with it - they are easy to strip and tend to bind. Use exactly a clean 2.5mm hex bit - don't substitute a Torx or other size. Press down and turn counterclockwise strongly and carefully to unscrew.
    • Once 4 screws are removed, if your box has LEDs, pay close attention to the next step before proceeding.
  3. Removing the lid, Disconnect LED cable: passo 3, immagine 1 di 3 Removing the lid, Disconnect LED cable: passo 3, immagine 2 di 3 Removing the lid, Disconnect LED cable: passo 3, immagine 3 di 3
    • If your box has LEDs, slowly tilt the edge of the case away, revealing the ribbon cable connected to the board.
    • Lift the lock in the direction of the ribbon cable, and you should feel the ribbon cable release.
    • You may now remove the ribbon cable from the board, and place the lid aside.
    • During reassembly, note that the ribbon cable contacts should face opposite the lock slider (as in photo). To re-insert the ribbon cable, first release the lock, insert the cable, then press the lock back down to latch it in place.
Conclusione
Matt Falcon
Membro da: 05/09/15
2.740 Reputazione
14 Guide realizzate
2Commenti sulla guida
Thank You! Since Enel X is bankrupt, is there a way to reset Amperage reduction setting back to full by pulling a coin battery or something on the PCB or a jumper?
danwat1234 - Replica
Enel is still active as of today. You should be able to re-connect your box via wifi to internet, and there server. Though a warning - it takes about 3 attempts and you still have to wait ~15~24 hours for your blue led to stay On. Once On, you can access from the Enel X app and reset your Current setting. Then once server is disconnected....one day soon, your charger will stay at that Current until your on-board battery dies. I'm in process of retrofitting a WiFi controller (Alexa, etc) so you can charge (w/o any current protection) at desired time-of-day. If you are interested, I can be reached here; pmp at christmas-songs-parody dot com
labear - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 20
Tutti i Tempi: 730
