Salta al contenuto principale
Removing the Samsung LA40R81BD 40in LCD TV Power Supply Board
Cosa ti serve
  1. Removing the Samsung LA40R81BD 40in LCD TV Power Supply Board, Rear Cover: passo 1, immagine 1 di 1
    • Unplug power cable and all AV cables from rear of TV and carefully lay TV face down on a clean flat working surface ensuring that you don't damage the LCD screen.
    • Using a Philips driver remove the 18 screws from the rear panel.
    • Gently lift the rear cover off the TV. You may need to wiggle the cover a little however there are no clips holding the cover on so it should come off easily if you have fully unscrewed all 18 screws.
  2. Removing the Samsung LA40R81BD 40in LCD TV Power Supply Board, Power Supply Board: passo 2, immagine 1 di 1
    • Remove the 7 connectors from the board
    • Remove the 7 screws from the board
    • Lift the main board away from the chassis ensuring you don's snag or catch any of the cables.
Conclusione
Altre 16 persone hanno completato questa guida.
Richdave
Membro da: 04/09/10
32.177 Reputazione
30 Guide realizzate
Master Techs Membro di Master Techs
Community
321 Membri
1.468 Guide realizzate
2 Commenti
Ma télé LCD Samsung ne veule pas s allume pas de courant que dois je faire s.v.p
Samir Chaaraoui - Replica
Vielen Dank für Ihren Artikel. Das Ausstecken ist für mich jetzt einfacher geworden! Ich hoffe, Sie können eine Anleitung zum Entfernen des Netzteils mit dem incredibox-Gerät geben.
Lily Collins - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 41
Tutti i Tempi: 7,586
