Salta al contenuto principale
Removing the Phone Keypad
Cosa ti serve
  1. Removing the Phone Keypad, Removing the Back Panel: passo 1, immagine 1 di 2 Removing the Phone Keypad, Removing the Back Panel: passo 1, immagine 2 di 2
    • Orient the phone so that the phone model and other descriptive information is facing upward.
    • Locate the two silver screws near the hinge where the battery is housed.
    • Remove the silver screws using a Phillips head #2 screwdriver.
  2. Removing the Phone Keypad: passo 2, immagine 1 di 3 Removing the Phone Keypad: passo 2, immagine 2 di 3 Removing the Phone Keypad: passo 2, immagine 3 di 3
    • Pull off the back panel of the phone.
    • Make sure you pull the cover off carefully in order to prevent damage to the back cover.
  3. Removing the Phone Keypad, Keypad: passo 3, immagine 1 di 2 Removing the Phone Keypad, Keypad: passo 3, immagine 2 di 2
    • Locate and unscrew the circled screw using a Philips head #2 screw driver or screw driver head.
  4. Removing the Phone Keypad: passo 4, immagine 1 di 1
    • Lift the motherboard away from the phone housing.
    • Be careful when lifting the motherboard. To prevent damage to the motherboard, gradually lift it from its place in the assembly.
  5. Removing the Phone Keypad: passo 5, immagine 1 di 2 Removing the Phone Keypad: passo 5, immagine 2 di 2
    • Now that the motherboard has been lifted out of place, the keypad can be accessed.
    • Using your fingers push the buttons from the the phone toward the lifted motherboard.
    • Remove the keypad from the assembly.
Conclusione
Clemson, Team 15-1, Benson Fall 2012 Membro di Clemson, Team 15-1, Benson Fall 2012
CLEM-BENSON-F12S15G1
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 11
Tutti i Tempi: 952
