Introduzione
You will learn how to remove scroll wheel from the wheel mount.
Cosa ti serve
Hold the mouse so that the bottom is facing up.
Remove the single Phillips #1 screw from the bottom half of the mouse.
Place the mouse so that the bottom is resting against a hard surface.
Lift the top cover of the mouse gently, and remove it.
The cover doesn’t lift straight up on my model - once you raise the back slightly as shown, gently pull it backward (parallel to the table top, away from the cord) to disengage two plastic clips that connect the bottom to the top.
Locate the scroll wheel on the mouse.
Grab the scroll wheel with your thumb and index finger.
Gently lift up, to remove the scroll wheel from the mouse.
Good information!
My mouse is like new again.
Many thanks
Locate the spring on the scroll wheel, and carefully remove the spring.
Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down.
Altre 2 persone hanno completato questa guida.
Un commento
Thank you! The photographs with good resolution and correct lighting made everything clear and comprehencible.
باز کردن پیچ زیر موس
h sh - Replica
There may be a sticker covering the screw hole.
Eric Jensen - Replica
