Salta al contenuto principale
Removing the Logitech MBJ58 Scroll Wheel from its Mount
Cosa ti serve
  1. Removing the Logitech MBJ58 Scroll Wheel from its Mount, Top cover: passo 1, immagine 1 di 1
    • Hold the mouse so that the bottom is facing up.
    • Remove the single Phillips #1 screw from the bottom half of the mouse.
  2. Removing the Logitech MBJ58 Scroll Wheel from its Mount: passo 2, immagine 1 di 2 Removing the Logitech MBJ58 Scroll Wheel from its Mount: passo 2, immagine 2 di 2
    • Place the mouse so that the bottom is resting against a hard surface.
    • Lift the top cover of the mouse gently, and remove it.
  3. Removing the Logitech MBJ58 Scroll Wheel from its Mount, Removing the Logitech MBJ58 Mouse Scroll Wheel: passo 3, immagine 1 di 3 Removing the Logitech MBJ58 Scroll Wheel from its Mount, Removing the Logitech MBJ58 Mouse Scroll Wheel: passo 3, immagine 2 di 3 Removing the Logitech MBJ58 Scroll Wheel from its Mount, Removing the Logitech MBJ58 Mouse Scroll Wheel: passo 3, immagine 3 di 3
    • Locate the scroll wheel on the mouse.
    • Grab the scroll wheel with your thumb and index finger.
    • Gently lift up, to remove the scroll wheel from the mouse.
  4. Removing the Logitech MBJ58 Scroll Wheel from its Mount, Support Spring: passo 4, immagine 1 di 2 Removing the Logitech MBJ58 Scroll Wheel from its Mount, Support Spring: passo 4, immagine 2 di 2
    • Locate the spring on the scroll wheel, and carefully remove the spring.
  5. Removing the Logitech MBJ58 Scroll Wheel from its Mount, Attaching the New Spring: passo 5, immagine 1 di 2 Removing the Logitech MBJ58 Scroll Wheel from its Mount, Attaching the New Spring: passo 5, immagine 2 di 2
    • Place the replacement spring on the correct side of the wheel (shown in the images) with the prongs pointing down.
  6. Removing the Logitech MBJ58 Scroll Wheel from its Mount, Wheel Mount: passo 6, immagine 1 di 3 Removing the Logitech MBJ58 Scroll Wheel from its Mount, Wheel Mount: passo 6, immagine 2 di 3 Removing the Logitech MBJ58 Scroll Wheel from its Mount, Wheel Mount: passo 6, immagine 3 di 3
    • Locate the black wheel mount.
    • Note: Make sure that the spring hidden in the mount does not fall out.
    • Separate the wheel from its mount.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 5-14, Forte Winter 2013 Membro di Cal Poly, Team 5-14, Forte Winter 2013
CPSU-FORTE-W13S5G14
5 Membri
23 Guide realizzate
2Commenti sulla guida
Thank you! The photographs with good resolution and correct lighting made everything clear and comprehencible.
Антон Вакаренко - Replica
Very helpful, thank you!
K.S. - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 37
Tutti i Tempi: 2,003
