Salta al contenuto principale
Removing the HP Compaq dx2000MT Optical (CD) Drive
Cosa ti serve
  1. Removing the HP Compaq dx2000MT Optical (CD) Drive, Removing the HP Compaq dx2000MT Case Doors: passo 1, immagine 1 di 1
    • Turn off your computer and remove the power cable by pulling it straight out of its socket.
  2. Removing the HP Compaq dx2000MT Optical (CD) Drive: passo 2, immagine 1 di 2 Removing the HP Compaq dx2000MT Optical (CD) Drive: passo 2, immagine 2 di 2
    • Remove the two Phillips #2 screws that secure the case door to the device.
  3. Removing the HP Compaq dx2000MT Optical (CD) Drive: passo 3, immagine 1 di 3 Removing the HP Compaq dx2000MT Optical (CD) Drive: passo 3, immagine 2 di 3 Removing the HP Compaq dx2000MT Optical (CD) Drive: passo 3, immagine 3 di 3
    • Remove the side case door by pushing towards the rear of the device with your hand.
    • This may take considerable force so keep pushing!
    • Once you slide the door back, remove it by pulling it outwards from the device.
  4. Removing the HP Compaq dx2000MT Optical (CD) Drive: passo 4, immagine 1 di 3 Removing the HP Compaq dx2000MT Optical (CD) Drive: passo 4, immagine 2 di 3 Removing the HP Compaq dx2000MT Optical (CD) Drive: passo 4, immagine 3 di 3
    • Once again, this may take considerable force.
  5. Removing the HP Compaq dx2000MT Optical (CD) Drive, Optical (CD) Drive: passo 5, immagine 1 di 3 Removing the HP Compaq dx2000MT Optical (CD) Drive, Optical (CD) Drive: passo 5, immagine 2 di 3 Removing the HP Compaq dx2000MT Optical (CD) Drive, Optical (CD) Drive: passo 5, immagine 3 di 3
    • Remove the IDE data cable and the power cable from the optical drive by pulling away from the drive.
  6. Removing the HP Compaq dx2000MT Optical (CD) Drive: passo 6, immagine 1 di 2 Removing the HP Compaq dx2000MT Optical (CD) Drive: passo 6, immagine 2 di 2
    • Remove the 2 Torx T15 screws holding the optical drive in place.
  7. Removing the HP Compaq dx2000MT Optical (CD) Drive: passo 7, immagine 1 di 2 Removing the HP Compaq dx2000MT Optical (CD) Drive: passo 7, immagine 2 di 2
    • Remove the other 2 Torx T15 screws holding the other side of the drive in place.
  8. Removing the HP Compaq dx2000MT Optical (CD) Drive: passo 8, immagine 1 di 3 Removing the HP Compaq dx2000MT Optical (CD) Drive: passo 8, immagine 2 di 3 Removing the HP Compaq dx2000MT Optical (CD) Drive: passo 8, immagine 3 di 3
    • Remove the optical drive by sliding it out the front of the device.
Conclusione
Logan Pace
Membro da: 10/12/11
2.278 Reputazione
9 Guide realizzate
Cal Poly, Team 17-16, Regan Fall 2011 Membro di Cal Poly, Team 17-16, Regan Fall 2011
CPSU-REGAN-F11S17G16
4 Membri
17 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,508
