Introduzione
This guide is base on the official service manual which I have attached to the device page and has been created using photos contained in other iFixit guides.
Parti
Nessuna parte richiesta.
Place the laptop upside down on a clean, flat surface.
  • Place the laptop upside down on a clean, flat surface.
  • Locate the battery release button with the padlock symbol above it.
  • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
    • The battery is now released from the battery compartment.
  • Gently remove the battery from the side of the laptop.
Aggiungi Commento
Place laptop upsid down on a clean flat work surface.
  • Place laptop upsid down on a clean flat work surface.
  • Remove the Philips M2.5 x 8 mm screw
  • Loosen the screw that holds the memory compartment closed
  • remove the memory module compartment cover
  • Press the Optical Drive release lever to the right and the optical drive should slide out of the case
Aggiungi Commento
Conclusione
Richdave
Membro da: 09/04/2010
28.204 Reputazione
30 Guide realizzate
Master Techs Membro di Master Techs
Community
277 Membri
748 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 15
Tutti i Tempi: 285
