Salta al contenuto principale
Removing the Dell Inspiron 1150 Modem Card
Cosa ti serve
  1. Removing the Dell Inspiron 1150 Modem Card, Removing Dell Inspiron 1150 Battery: passo 1, immagine 1 di 3 Removing the Dell Inspiron 1150 Modem Card, Removing Dell Inspiron 1150 Battery: passo 1, immagine 2 di 3 Removing the Dell Inspiron 1150 Modem Card, Removing Dell Inspiron 1150 Battery: passo 1, immagine 3 di 3
    • Place the laptop upside down on a clean, flat surface.
    • Locate the battery release button with the padlock symbol above it.
    • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
    • The battery is now released from the battery compartment.
    • Gently remove the battery from the side of the laptop.
  2. Removing the Dell Inspiron 1150 Modem Card, Modem Card: passo 2, immagine 1 di 3 Removing the Dell Inspiron 1150 Modem Card, Modem Card: passo 2, immagine 2 di 3 Removing the Dell Inspiron 1150 Modem Card, Modem Card: passo 2, immagine 3 di 3
    • Turn the laptop upside down and locate the panel labeled C
    • Unscrew the single screw holding the cover in place.
    • Lift up the cover and remove it to expose the Modem Card.
  3. Removing the Dell Inspiron 1150 Modem Card: passo 3, immagine 1 di 2 Removing the Dell Inspiron 1150 Modem Card: passo 3, immagine 2 di 2
    • Locate the Modem card.
    • Remove the screws.
  4. Removing the Dell Inspiron 1150 Modem Card: passo 4, immagine 1 di 2 Removing the Dell Inspiron 1150 Modem Card: passo 4, immagine 2 di 2
    • Pull tab to lift the card out of the connector on the main board.
    • Disconnect the cable attached to the left edge of the Modem card
Linea Traguardo
Lauren
Membro da: 04/25/10
4 Reputazione
2 Guide realizzate
Cal Poly, Team 16-2, Maness Spring 2010 Membro di Cal Poly, Team 16-2, Maness Spring 2010
CPSU-MANESS-S10S16G2
4 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 4,529
