Salta al contenuto principale
Removing the Dell Inspiron 1150 Keyboard
Cosa ti serve
  1. Removing the Dell Inspiron 1150 Keyboard, Removing Dell Inspiron 1150 Battery: passo 1, immagine 1 di 3 Removing the Dell Inspiron 1150 Keyboard, Removing Dell Inspiron 1150 Battery: passo 1, immagine 2 di 3 Removing the Dell Inspiron 1150 Keyboard, Removing Dell Inspiron 1150 Battery: passo 1, immagine 3 di 3
    • Place the laptop upside down on a clean, flat surface.
    • Locate the battery release button with the padlock symbol above it.
    • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
    • The battery is now released from the battery compartment.
    • Gently remove the battery from the side of the laptop.
  2. Removing the Dell Inspiron 1150 Keyboard, Keyboard: passo 2, immagine 1 di 3 Removing the Dell Inspiron 1150 Keyboard, Keyboard: passo 2, immagine 2 di 3 Removing the Dell Inspiron 1150 Keyboard, Keyboard: passo 2, immagine 3 di 3
    • Use a spudger to lift the notched right edge of the hinge cover, and pry it loose
    • You need to lay the LCD screen down flat to allow the hinge cover to be lifted off
    • Lift the hinge cover off and set aside
  3. Removing the Dell Inspiron 1150 Keyboard: passo 3, immagine 1 di 3 Removing the Dell Inspiron 1150 Keyboard: passo 3, immagine 2 di 3 Removing the Dell Inspiron 1150 Keyboard: passo 3, immagine 3 di 3
    • Remove 4ea M2 x 3mm keyboard screws
    • Lift up keyboard from the rear to expose the connector below
    • Disconnect the keyboard ribbon cable from the mother board
Conclusione
Richdave
Membro da: 04/09/10
32.150 Reputazione
30 Guide realizzate
Master Techs Membro di Master Techs
Community
321 Membri
1.466 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 17
Tutti i Tempi: 881
