Salta al contenuto principale
Removing the Dell Inspiron 1150 Display Assembly
Cosa ti serve
  1. Removing the Dell Inspiron 1150 Display Assembly, Removing Dell Inspiron 1150 Battery: passo 1, immagine 1 di 3 Removing the Dell Inspiron 1150 Display Assembly, Removing Dell Inspiron 1150 Battery: passo 1, immagine 2 di 3 Removing the Dell Inspiron 1150 Display Assembly, Removing Dell Inspiron 1150 Battery: passo 1, immagine 3 di 3
    • Place the laptop upside down on a clean, flat surface.
    • Locate the battery release button with the padlock symbol above it.
    • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
    • The battery is now released from the battery compartment.
    • Gently remove the battery from the side of the laptop.
  2. Removing the Dell Inspiron 1150 Display Assembly, Hard Drive: passo 2, immagine 1 di 2 Removing the Dell Inspiron 1150 Display Assembly, Hard Drive: passo 2, immagine 2 di 2
    • Place laptop upside down on a clean flat surface.
    • Remove 2ea M2.5 x 5 mm screws.
    • Pull the HDD from main body of the laptop.
  3. Removing the Dell Inspiron 1150 Display Assembly, Optical Drive (Based on Dell Service Manual): passo 3, immagine 1 di 3 Removing the Dell Inspiron 1150 Display Assembly, Optical Drive (Based on Dell Service Manual): passo 3, immagine 2 di 3 Removing the Dell Inspiron 1150 Display Assembly, Optical Drive (Based on Dell Service Manual): passo 3, immagine 3 di 3
    • Place laptop upsid down on a clean flat work surface.
    • Remove the Philips M2.5 x 8 mm screw
    • Loosen the screw that holds the memory compartment closed
    • remove the memory module compartment cover
    • Press the Optical Drive release lever to the right and the optical drive should slide out of the case
  4. Removing the Dell Inspiron 1150 Display Assembly, Keyboard: passo 4, immagine 1 di 3 Removing the Dell Inspiron 1150 Display Assembly, Keyboard: passo 4, immagine 2 di 3 Removing the Dell Inspiron 1150 Display Assembly, Keyboard: passo 4, immagine 3 di 3
    • Use a spudger to lift the notched right edge of the hinge cover, and pry it loose
    • You need to lay the LCD screen down flat to allow the hinge cover to be lifted off
    • Lift the hinge cover off and set aside
  5. Removing the Dell Inspiron 1150 Display Assembly: passo 5, immagine 1 di 3 Removing the Dell Inspiron 1150 Display Assembly: passo 5, immagine 2 di 3 Removing the Dell Inspiron 1150 Display Assembly: passo 5, immagine 3 di 3
    • Remove 4ea M2 x 3mm keyboard screws
    • Lift up keyboard from the rear to expose the connector below
    • Disconnect the keyboard ribbon cable from the mother board
  6. Removing the Dell Inspiron 1150 Display Assembly, Display Assembly: passo 6, immagine 1 di 3 Removing the Dell Inspiron 1150 Display Assembly, Display Assembly: passo 6, immagine 2 di 3 Removing the Dell Inspiron 1150 Display Assembly, Display Assembly: passo 6, immagine 3 di 3
    • Remove 1ea M2.5 x 8mm screw holding the EMI shield in place
    • Remove the EMI shield to expose the LCD ribbon cable
    • Gently pull up on the tab to disconnect the ribbon cable from the main board
    • Close the lid carefully and remove the two M2.5 x 5-mm screws from the rear of the case
  7. Removing the Dell Inspiron 1150 Display Assembly: passo 7, immagine 1 di 3 Removing the Dell Inspiron 1150 Display Assembly: passo 7, immagine 2 di 3 Removing the Dell Inspiron 1150 Display Assembly: passo 7, immagine 3 di 3
    • Open the lid and support the Display Assembly while performing the next step to avoid it falling down when the hinge screws are removed
    • Remove 2e M2.5 x 5mm screws from each hinge bracket
    • The Display Assembly can now be lifted free of the laptop body
Conclusione
Altre 2 persone hanno completato questa guida.
Daniel
Membro da: 04/25/10
87 Reputazione
2 Guide realizzate
Cal Poly, Team 16-2, Maness Spring 2010 Membro di Cal Poly, Team 16-2, Maness Spring 2010
CPSU-MANESS-S10S16G2
4 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 16
Tutti i Tempi: 6,872
