Salta al contenuto principale
Logitech Webcam Pro 9000 Front and Back Cover Replacement
Cosa ti serve
  1. Logitech Webcam Pro 9000 Front and Back Cover Replacement, Front and Back Cover: passo 1, immagine 1 di 2 Logitech Webcam Pro 9000 Front and Back Cover Replacement, Front and Back Cover: passo 1, immagine 2 di 2
    • Remove the two 8 mm Phillips #0 screws on the back cover.
    • The motherboard connects the two covers together. DO NOT separate the two yet.
    • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
  2. Logitech Webcam Pro 9000 Front and Back Cover Replacement: passo 2, immagine 1 di 2 Logitech Webcam Pro 9000 Front and Back Cover Replacement: passo 2, immagine 2 di 2
    • Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
    • DO NOT detach the wire connecting the motherboard to the front cover.
Conclusione
Cal Poly, Team 12-34, Amido Spring 2013 Membro di Cal Poly, Team 12-34, Amido Spring 2013
CPSU-AMIDO-S13S12G34
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 19
Tutti i Tempi: 1,252
