Salta al contenuto principale
Removing the Back Panel
Cosa ti serve
  1. Removing the Back Panel, Removing the Back Panel: passo 1, immagine 1 di 3 Removing the Back Panel, Removing the Back Panel: passo 1, immagine 2 di 3 Removing the Back Panel, Removing the Back Panel: passo 1, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Place the tablet face down on a soft, stable surface that will protect the screen.
    • Next, Scrape off the seal over the screw in the back of the tablet with a Metal Spudger.
    • Use the Phillips #000 Screwdriver to remove the M1.4 × 2.5 screw.
    • If the seal covering the screw has already been removed, please proceed to the next step in the process.
    • As the screw is small, you may wish to extract it using a pair of tweezers.
  2. Removing the Back Panel: passo 2, immagine 1 di 3 Removing the Back Panel: passo 2, immagine 2 di 3 Removing the Back Panel: passo 2, immagine 3 di 3
    • Starting on the side, work your way around the the tablet to pop off the back cover. You will want to utilize a metal Spudger for this.
    • Some force may be required initially to pry the back cover off.
    • Note that the button tabs for this device are loose inside the case and will fall out when opening.
Conclusione
Altre 4 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 29
Tutti i Tempi: 2,772
