Salta al contenuto principale
Removing Texas Instruments TI-92 Back Cover
  1. Removing Texas Instruments TI-92 Back Cover, Back Cover: passo 1, immagine 1 di 3 Removing Texas Instruments TI-92 Back Cover, Back Cover: passo 1, immagine 2 di 3 Removing Texas Instruments TI-92 Back Cover, Back Cover: passo 1, immagine 3 di 3
    • The first step to any repair operation is to remove the front cover.
    • Grab the back of the calculator with one hand and the cover with the other.
    • Pull the cover off from one of the sides for easy removal.
  2. Removing Texas Instruments TI-92 Back Cover: passo 2, immagine 1 di 2 Removing Texas Instruments TI-92 Back Cover: passo 2, immagine 2 di 2
    • Orientate the calculator with the top facing towards you.
    • Slide the locking tab,found on the top part of the calculator, to the unlock position.
  3. Removing Texas Instruments TI-92 Back Cover: passo 3, immagine 1 di 2 Removing Texas Instruments TI-92 Back Cover: passo 3, immagine 2 di 2
    • "Locking Tab"
    • To remove the back cover, slide the cover away from the locking tab towards the bottom of the calculator until the cover no longer slides.
    • Then with the front of the calculator facing down, pull up on the back cover.
    • The calculator should now be orientated with the front facing down, as shown in picture 2.
Conclusione
Cal Poly, Team 15-51, Garner Spring 2010 Membro di Cal Poly, Team 15-51, Garner Spring 2010
CPSU-GARNER-S10S15G51
5 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 3,349
