Salta al contenuto principale
Removing Samsung ML2510 Back Panel
Cosa ti serve
  1. Removing Samsung ML2510 Back Panel, Removing Samsung ML2510 Back Panel: passo 1, immagine 1 di 3 Removing Samsung ML2510 Back Panel, Removing Samsung ML2510 Back Panel: passo 1, immagine 2 di 3 Removing Samsung ML2510 Back Panel, Removing Samsung ML2510 Back Panel: passo 1, immagine 3 di 3
    • Remove the top hinged panel by taking out the pins at the bottom of this panel.
  2. Removing Samsung ML2510 Back Panel: passo 2, immagine 1 di 1
    • Using a Phillips #2 screwdriver, remove the four screws on the back of the printer.
  3. Removing Samsung ML2510 Back Panel: passo 3, immagine 1 di 3 Removing Samsung ML2510 Back Panel: passo 3, immagine 2 di 3 Removing Samsung ML2510 Back Panel: passo 3, immagine 3 di 3
    • Gently lift the top panel while simultaneously pulling off the back panel.
    • Before pulling out the back panel entirely, make sure to remove the rear cooling fan from its slot.
Conclusione
Altre 4 persone hanno completato questa guida.
bbaustin
Membro da: 10/12/11
268 Reputazione
6 Guide realizzate
Cal Poly, Team 17-18, Regan Fall 2011 Membro di Cal Poly, Team 17-18, Regan Fall 2011
CPSU-REGAN-F11S17G18
4 Membri
12 Guide realizzate
3 Commenti
Very easy to follow. I think I would have broken something if I had not followed these simple steps.
rob - Replica
Thank you on how to do this. A little force is required to lift the top cover edges one by one to get the back cover off, but it does come off, without taking the top cover off. I think my solenoid is bad, as the printer takes two sheets of paper initially and then more right afterwards. The rubber pick up wheel seems to be fine after cleaning, as it picks up the paper without issue, just multiple sheets is all.
kirkdcharles - Replica
Thanks. I would have broken the top cover or back panel if I did not read your post. It take a little force to pull the back cover off while applying upward pressure to the top cover ends, one at a time. I think I have to replace the solenoid as the rubber pick up wheel pulls the paper up fine, but multiple sheets after the first rotation of the wheel.
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 6,103
