Salta al contenuto principale
Removing Philips DC320 37 Bottom Panel
Cosa ti serve
  1. Removing Philips DC320 37 Bottom Panel, Docking entertainment system: passo 1, immagine 1 di 1
    • Pry off the four white feet with the pointed end of the spudger
  2. Removing Philips DC320 37 Bottom Panel: passo 2, immagine 1 di 1
    • Gently unscrew the four 15.5 mm Phillips #2 screws that hold the bottom panel to the dock.
  3. Removing Philips DC320 37 Bottom Panel: passo 3, immagine 1 di 1
    • Use the flat end of the spudger to pry the lid off from the two connectors holding it to the body of the dock.
    • The connectors on the panel are fragile and may break.
  4. Removing Philips DC320 37 Bottom Panel: passo 4, immagine 1 di 3 Removing Philips DC320 37 Bottom Panel: passo 4, immagine 2 di 3 Removing Philips DC320 37 Bottom Panel: passo 4, immagine 3 di 3
    • Carefully pull up and out the four electrical connectors and two ribbon connectors that connect the bottom panel to the dock.
    • Electrical Connectors
    • Ribbon Connectors
    • The cables do not have a lot of slack in them. Be careful not to break the connectors.
    • One wire is soldered onto the bottom panel. Be careful not to break this bond.
Conclusione
Altre 2 persone hanno completato questa guida.
Greg Lane
Membro da: 04/16/13
39 Reputazione
4 Guide realizzate
Cal Poly, Team 3-48, Amido Spring 2013 Membro di Cal Poly, Team 3-48, Amido Spring 2013
CPSU-AMIDO-S13S3G48
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 14
Tutti i Tempi: 406
