Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
You must remove the battery, the front, and the rear casing before removing the flash assembly.
Parti
Nessuna parte specificata.
  1. The battery compartment is located on the bottom side of the camera.  Push the button in, and slide the cover to get access to the batteries. The battery compartment is located on the bottom side of the camera.  Push the button in, and slide the cover to get access to the batteries.
    • The battery compartment is located on the bottom side of the camera. Push the button in, and slide the cover to get access to the batteries.
  2. The batteries will slide right out. When putting new batteries in, make sure they are pointing the right direction.
    • The batteries will slide right out.
    • When putting new batteries in, make sure they are pointing the right direction.
  3. Remove the 7 screws holding the front case in place, with a #00 screwdriver. Six screws are 3.6 mm. The seventh screw is 3.2 mm.
    • Remove the 7 screws holding the front case in place, with a #00 screwdriver.
    • Six screws are 3.6 mm.
    • The seventh screw is 3.2 mm.
  4. Pulling the front case off, requires applying enough strength in the right areas. The front case snaps into place in three places: At the top and bottom of the battery side (opposite of side pictured) of the case.
    • Pulling the front case off, requires applying enough strength in the right areas.
    • The front case snaps into place in three places:
    • At the top and bottom of the battery side (opposite of side pictured) of the case.
    • Right in the middle of the DC-in side (side pictured) of the case.
    • Top of the camera, to the left of the power button.
    • Once those places are disconnected, the front case will pop right off.
    • The camera in the first two pictures is upside down. This is the best position to place your thumbs to remove the case.
  5. Kit per Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  6. Remove the 3.2 mm screw in the battery compartment using a #00 screwdriver.
    • Remove the 3.2 mm screw in the battery compartment using a #00 screwdriver.
    • After removal of the screw the case will be loose, but do not tug it off. There is a cord connecting the rear controls to the motherboard.
  7. Carefully pull the rear case away from the camera until you have access to the cord connected to the motherboard. Lift the white latch using a fingernail or a spudger. Pull the cord from its connector.
    • Carefully pull the rear case away from the camera until you have access to the cord connected to the motherboard.
    • Lift the white latch using a fingernail or a spudger.
    • Pull the cord from its connector.
  8. Remove the two 2.7 mm screws using a #00 screwdriver. Remove the two 2.7 mm screws using a #00 screwdriver.
    • Remove the two 2.7 mm screws using a #00 screwdriver.
  9. Remove the metal casing on the flash, by grabbing with two fingers and pry it off the snaps connecting it to the flash. Remove the plastic cover on the flash, by simply grabbing the plastic with two fingers and pulling.
    • Remove the metal casing on the flash, by grabbing with two fingers and pry it off the snaps connecting it to the flash.
    • Remove the plastic cover on the flash, by simply grabbing the plastic with two fingers and pulling.
  10. Remove the 2.7 mm screw holding the front circuit board in place. Remove the 2.7 mm screw holding the front circuit board in place.
    • Remove the 2.7 mm screw holding the front circuit board in place.
  11. Remove the circuit board by prying it out with a spudger. Remove the flashbulb from its place. When taking out the flash bulb, be sure to carefully remove the wire taped to the back of the bulb (as shown in the second image). Gently separate the tape and the wire.
    • Remove the circuit board by prying it out with a spudger.
    • Remove the flashbulb from its place.
    • When taking out the flash bulb, be sure to carefully remove the wire taped to the back of the bulb (as shown in the second image). Gently separate the tape and the wire.
  12. To remove the capacitor you must slide it out from the sticky tape that is holding it in place. First insert a spudger between the capacitor and the plastic. Pry with the spudger or pull with your hands to loosen the capacitor.
    • To remove the capacitor you must slide it out from the sticky tape that is holding it in place.
    • First insert a spudger between the capacitor and the plastic.
    • Pry with the spudger or pull with your hands to loosen the capacitor.
    • Capacitors can contain a lot of energy. If you touch the terminals you could get a strong shock. So be careful to avoid the terminals with your fingers and don't use any metal tools to interact with the capacitor.
    • The capacitor can be difficult to loosen at first, give it strong pulls and pushes and it should come out.
Conclusione
Matt
Membro da: 25/01/2011
781 Reputazione
6 Guide realizzate
Cal Poly, Team 4-36, Regan Winter 2011 Membro di Cal Poly, Team 4-36, Regan Winter 2011
CPSU-REGAN-W11S4G36
3 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 2,323
