Salta al contenuto principale
Nokia 3100b Screen Replacement
Cosa ti serve
  1. Nokia 3100b Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Make sure your phone is turned off.
  2. Nokia 3100b Screen Replacement: passo 2, immagine 1 di 1
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
  3. Nokia 3100b Screen Replacement, SIM Card: passo 3, immagine 1 di 1
    • Gently pull back the small metal frame holding the SIM card into place, and lift open the frame.
  4. Nokia 3100b Screen Replacement: passo 4, immagine 1 di 1
    • Retrieve your SIM card.
  5. Nokia 3100b Screen Replacement, Screen: passo 5, immagine 1 di 1
    • Separate the front cover from the main body of the phone.
  6. Nokia 3100b Screen Replacement: passo 6, immagine 1 di 1
    • Remove the six screws along the edges of the phone.
  7. Nokia 3100b Screen Replacement: passo 7, immagine 1 di 1
    • Pull the screen assembly from the base of the phone.
  8. Nokia 3100b Screen Replacement: passo 8, immagine 1 di 1
    • Carefully lift the keypad portion of the screen assembly from the circuit board.
  9. Nokia 3100b Screen Replacement: passo 9, immagine 1 di 1
    • Separate the screen from the circuit board.
    • Reconnect the ports during reassembly or the screen will not function properly.
    • Remember to reconnect the screen to the circuit board when reassembling!
  10. Nokia 3100b Screen Replacement: passo 10, immagine 1 di 1
    • Gently push down on the screen to pop it off of the assembly.
  11. Nokia 3100b Screen Replacement: passo 11, immagine 1 di 1
    • When the screen falls out the assembly, two white tabs will fall out with it.
    • When reinstalling the screen, insert the tabs with the slanted side pointing upwards so they slide into the assembly.
Conclusione
Cal Poly, Team 29-64, Johann Spring 2010 Membro di Cal Poly, Team 29-64, Johann Spring 2010
CPSU-JOHANN-S10S29G64
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,763
