Salta al contenuto principale
Removing Nokia 3100b Keypad
  1. Removing Nokia 3100b Keypad, Battery: passo 1, immagine 1 di 1
    • Make sure your phone is turned off.
  2. Removing Nokia 3100b Keypad: passo 2, immagine 1 di 1
    • Press the button on the back of the phone and slide the back panel off.
    • Remove the battery by pulling it from the phone.
  3. Removing Nokia 3100b Keypad, Removing Nokia 3100b Keypad: passo 3, immagine 1 di 1
    • Push the black tabs down and pull the colored half of the phone from the white half.
  4. Removing Nokia 3100b Keypad: passo 4, immagine 1 di 1
    • The front part of the phone is now removed. Make sure nothing was damaged while removing the front cover.
  5. Removing Nokia 3100b Keypad: passo 5, immagine 1 di 1
    • Remove the keypad membrane by pulling it from the front cover.
Conclusione
Cal Poly, Team 29-64, Johann Spring 2010 Membro di Cal Poly, Team 29-64, Johann Spring 2010
CPSU-JOHANN-S10S29G64
3 Membri
8 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 9
Tutti i Tempi: 887
