Salta al contenuto principale
Removing Nikon Coolpix 4600 Front and Rear case
Cosa ti serve
  1. Removing Nikon Coolpix 4600 Front and Rear case, Front and Rear Case: passo 1, immagine 1 di 2 Removing Nikon Coolpix 4600 Front and Rear case, Front and Rear Case: passo 1, immagine 2 di 2
    • Find the six screws on the exterior of the camera: two 3.3 mm screws on the bottom and two 5.25 mm screws on both the left and right sides.
    • Using a Phillips 00 screwdriver, remove all of the six screws.
  2. Removing Nikon Coolpix 4600 Front and Rear case: passo 2, immagine 1 di 2 Removing Nikon Coolpix 4600 Front and Rear case: passo 2, immagine 2 di 2
    • Gently separate the front and back casing by pulling them apart with your hands, being careful not to damage any internal components.
    • The front case is attached to internal components and cannot be removed independently.
  3. Removing Nikon Coolpix 4600 Front and Rear case: passo 3, immagine 1 di 1
    • Examine the connection between the ribbon cable and the motherboard closely. Identify the two grey tabs on each side of the connecting bracket.
    • Slide the grey tabs toward the bottom of the camera to release the ribbon cable. Gently disconnect the ribbon cable from the motherboard.
    • Once the ribbon cable is disconnected, you can now carefully separate the back case from the front case.
Conclusione
Cal Poly, Team 9-43, Regan Spring 2012 Membro di Cal Poly, Team 9-43, Regan Spring 2012
CPSU-REGAN-S12S9G43
5 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,575
