Salta al contenuto principale
Removing Nikon Coolpix 4600 Front and Rear case
Cosa ti serve
  1. Removing Nikon Coolpix 4600 Front and Rear case, Front and Rear Case: passo 1, immagine 1 di 2 Removing Nikon Coolpix 4600 Front and Rear case, Front and Rear Case: passo 1, immagine 2 di 2
    • Locate the six screws on the outside of the camera (2 3.3 mm on the bottom, 2 5.25 mm on the left, and 2 5.25 mm on the right).
    • Using a Phillips 00 screwdriver, remove all of the six screws.
  2. Removing Nikon Coolpix 4600 Front and Rear case: passo 2, immagine 1 di 2 Removing Nikon Coolpix 4600 Front and Rear case: passo 2, immagine 2 di 2
    • Carefully pull the front and back case apart.
    • The front case is attached to internal components and cannot be removed independently.
  3. Removing Nikon Coolpix 4600 Front and Rear case: passo 3, immagine 1 di 1
    • Look closely at the connection between the ribbon cable and the motherboard. Locate the two grey tabs on either side of the connecting bracket.
    • Slide the grey tabs toward the bottom of camera. Gently disconnect the ribbon cable from the motherboard.
    • After disconnecting the data ribbon, you can now separate the back case from the front case.
Conclusione
Cal Poly, Team 9-43, Regan Spring 2012 Membro di Cal Poly, Team 9-43, Regan Spring 2012
CPSU-REGAN-S12S9G43
5 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 20
Tutti i Tempi: 1,493
