Salta al contenuto principale
Motorola V60i Back Plate Replacement
Cosa ti serve
  1. Motorola V60i Back Plate Replacement, Battery: passo 1, immagine 1 di 2 Motorola V60i Back Plate Replacement, Battery: passo 1, immagine 2 di 2
    • Flip the phone over so the back cover is facing up.
    • Using either a finger or a spudger, press the button located near the top of the phone by the antenna.
  2. Motorola V60i Back Plate Replacement: passo 2, immagine 1 di 2 Motorola V60i Back Plate Replacement: passo 2, immagine 2 di 2
    • Pry up the back plate from the phone.
    • Push the button near the bottom of the battery using either your finger or the spudger to release the battery.
  3. Motorola V60i Back Plate Replacement, Back Plate: passo 3, immagine 1 di 1
    • Using a T6 Torx screwdriver, remove the four screws from the back of the phone.
  4. Motorola V60i Back Plate Replacement: passo 4, immagine 1 di 2 Motorola V60i Back Plate Replacement: passo 4, immagine 2 di 2
    • Simultaneously press the highlighted buttons on both sides of phone.
  5. Motorola V60i Back Plate Replacement: passo 5, immagine 1 di 1
    • Separate the back plate from the rest of phone.
    • Do not pull the wire connecting the front and back plates.
Conclusione
Cal Poly, Team 30-40, Garner Spring 2010 Membro di Cal Poly, Team 30-40, Garner Spring 2010
CPSU-GARNER-S10S30G40
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 3,525
