Introduzione
Step-by-step guide to removing your phone's antenna.
  1. The antenna is located on top right corner of the phone while the front of the phone is facing you. Unscrew the antenna clockwise until it is loose enough to remove from the phone. Unscrew the antenna clockwise until it is loose enough to remove from the phone.
    • The antenna is located on top right corner of the phone while the front of the phone is facing you.
    • Unscrew the antenna clockwise until it is loose enough to remove from the phone.
  2. Spedizione gratuita per tutti gli ordini superiori a 100,00 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
Conclusione
Cal Poly, Team 30-40, Garner Spring 2010 Membro di Cal Poly, Team 30-40, Garner Spring 2010
CPSU-GARNER-S10S30G40
4 Membri
14 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 9
Tutti i Tempi: 2,915
