Salta al contenuto principale
Removing Minolta X-370 Lens Holder
Cosa ti serve
  1. Removing Minolta X-370 Lens Holder, Minolta X-370 Battery Replacement: passo 1, immagine 1 di 2 Removing Minolta X-370 Lens Holder, Minolta X-370 Battery Replacement: passo 1, immagine 2 di 2
    • Flip the camera so that the bottom is facing you.
    • Take a spare coin and unscrew the battery cover off.
  2. Removing Minolta X-370 Lens Holder: passo 2, immagine 1 di 1
    • Remove the batteries, making sure to note their proper alignment.
  3. Removing Minolta X-370 Lens Holder, Bottom Cover: passo 3, immagine 1 di 2 Removing Minolta X-370 Lens Holder, Bottom Cover: passo 3, immagine 2 di 2
    • Remove two 4.8mm screws.
    • Remove one 3.4mm screw.
    • Remove one 2.65mm screw.
    • Lift off the back cover.
  4. Removing Minolta X-370 Lens Holder: passo 4, immagine 1 di 1
    • Remove three 3.5mm screws.
    • Remove two 3.8mm screws.
    • Remove one 6.35mm screw.
    • Remove one 4mm screw. Lift off the disk.
    • Remove one 5.11mm screw.
  5. Removing Minolta X-370 Lens Holder: passo 5, immagine 1 di 1
    • Lift up the silver, metal piece
    • Please note that some internal pieces may come loose during this process.
  6. Removing Minolta X-370 Lens Holder, Lens Holder: passo 6, immagine 1 di 3 Removing Minolta X-370 Lens Holder, Lens Holder: passo 6, immagine 2 di 3 Removing Minolta X-370 Lens Holder, Lens Holder: passo 6, immagine 3 di 3
    • Remove four 4.45mm screws and remove the alignment ring.
    • Remove the interior metal ring and the black plastic ring. Pay attention to the spring's location.
    • Pay attention to the alignment of the interior metal ring and the black plastic ring.
  7. Removing Minolta X-370 Lens Holder: passo 7, immagine 1 di 3 Removing Minolta X-370 Lens Holder: passo 7, immagine 2 di 3 Removing Minolta X-370 Lens Holder: passo 7, immagine 3 di 3
    • Remove the two black stoppers.
    • Using the metal spudger, remove the two triangular hangers.
  8. Removing Minolta X-370 Lens Holder: passo 8, immagine 1 di 2 Removing Minolta X-370 Lens Holder: passo 8, immagine 2 di 2
    • Using the metal spudger, peel off the right leather cover.
    • Be careful not to tear the cover because you will need to use it again.
  9. Removing Minolta X-370 Lens Holder: passo 9, immagine 1 di 3 Removing Minolta X-370 Lens Holder: passo 9, immagine 2 di 3 Removing Minolta X-370 Lens Holder: passo 9, immagine 3 di 3
    • Use the metal spudger to remove both the grip cover and the left leather cover.
    • Be careful not to tear the covers because you will need to use them again.
  10. Removing Minolta X-370 Lens Holder: passo 10, immagine 1 di 2 Removing Minolta X-370 Lens Holder: passo 10, immagine 2 di 2
    • Remove two 5.3mm screws.
    • Remove one 2.35mm screws.
  11. Removing Minolta X-370 Lens Holder: passo 11, immagine 1 di 2 Removing Minolta X-370 Lens Holder: passo 11, immagine 2 di 2
    • Remove the left and right plastic covers.
  12. Removing Minolta X-370 Lens Holder: passo 12, immagine 1 di 3 Removing Minolta X-370 Lens Holder: passo 12, immagine 2 di 3 Removing Minolta X-370 Lens Holder: passo 12, immagine 3 di 3
    • Remove two 6.65mm screws.
    • Remove two 2.93mm screws.
    • Remove four 5.3mm screws.
    • Remove the black plastic lens holder.
Conclusione
Altre 4 persone hanno completato questa guida.
Nick
Membro da: 04/19/11
525 Reputazione
4 Guide realizzate
Cal Poly, Team 8-7, Regan Spring 2011 Membro di Cal Poly, Team 8-7, Regan Spring 2011
CPSU-REGAN-S11S8G7
4 Membri
4 Guide realizzate
Un commento
I have Problems to assemble the new black plastic lens holder.
The space between camera Cup and the housing is very low.
Did someone have the same Problems ?
Klaus Kohlhas - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 17
Tutti i Tempi: 6,950
