Salta al contenuto principale
Removing Minolta X-370 Bottom Cover
Cosa ti serve
  1. Removing Minolta X-370 Bottom Cover, Minolta X-370 Battery Replacement: passo 1, immagine 1 di 2 Removing Minolta X-370 Bottom Cover, Minolta X-370 Battery Replacement: passo 1, immagine 2 di 2
    • Flip the camera so that the bottom is facing you.
    • Take a spare coin and unscrew the battery cover off.
  2. Removing Minolta X-370 Bottom Cover: passo 2, immagine 1 di 1
    • Remove the batteries, making sure to note their proper alignment.
    Hi just checking which type of batteries are required? You have two types listed, the SR44/LR44 (I understand those are the same types of batteries) then the CR-1 / 3 /3N 3V battery? How many batteries do I need and which type will I need? thanks!
    Juliette Perry-Dumarquez - Replica
  3. Removing Minolta X-370 Bottom Cover, Bottom Cover: passo 3, immagine 1 di 2 Removing Minolta X-370 Bottom Cover, Bottom Cover: passo 3, immagine 2 di 2
    • Remove two 4.8mm screws.
    • Remove one 3.4mm screw.
    • Remove one 2.65mm screw.
    • Lift off the back cover.
  4. Removing Minolta X-370 Bottom Cover: passo 4, immagine 1 di 1
    • Remove three 3.5mm screws.
    • Remove two 3.8mm screws.
    • Remove one 6.35mm screw.
    • Remove one 4mm screw. Lift off the disk.
    • Remove one 5.11mm screw.
  5. Removing Minolta X-370 Bottom Cover: passo 5, immagine 1 di 1
    • Lift up the silver, metal piece
    • Please note that some internal pieces may come loose during this process.
Conclusione
Altre 3 persone hanno completato questa guida.
Nick
Membro da: 04/19/11
525 Reputazione
4 Guide realizzate
Cal Poly, Team 8-7, Regan Spring 2011 Membro di Cal Poly, Team 8-7, Regan Spring 2011
CPSU-REGAN-S11S8G7
4 Membri
8 Guide realizzate
Un commento
good advice, will use, have multiple Minolta cameras to work with.
gabriel johnson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 30
Tutti i Tempi: 10,749
