Salta al contenuto principale
Removing Mercedes W123 Instrument Cluster
Cosa ti serve
  1. Removing Mercedes W123 Instrument Cluster, Instrument Cluster: passo 1, immagine 1 di 1
    • Begin by disconnecting your battery, pulling off the negative (-) ground cable.
    • This is required for this process! There is a constant 12v supply of power to your car's clock, even when the key is off. If you attempt to pull the cluster out with the battery connected you will burn up part of your cluster's circuit board, or worse yet hurt yourself.
  2. Removing Mercedes W123 Instrument Cluster: passo 2, immagine 1 di 1
  3. Removing Mercedes W123 Instrument Cluster: passo 3, immagine 1 di 1
    • The cluster is held in by tension alone. There are no fasteners.
    • Reach up under the dash, feel your way past any wires and/or sound insulating material until you can touch the back of the cluster. Then push it firmly outwards towards the steering wheel.
  4. Removing Mercedes W123 Instrument Cluster: passo 4, immagine 1 di 1
    • Once the cluster starts to come out, you can pull it further out by the upper edge.
  5. Removing Mercedes W123 Instrument Cluster: passo 5, immagine 1 di 1
    • Pull the cluster out until you feel the tension of the speedometer cable.
    • Normally, there will be just barely enough room for you to get your hand behind the cluster. You will need to feel around the center of the cluster, behind and to the right of the center of the speedometer cable, for the connection for the speedometer cable.
    • The cable screws on to the back of the cluster with a knurled knob. It is to be loosened by hand. No tools will be necessary to unscrew this. Unscrew the cable until it is free of the cluster.
    • If your speedometer cable is especially taut behind the cluster, you may need to go back to step 2 and try to remove it by feel before pushing the cluster out by hand.
  6. Removing Mercedes W123 Instrument Cluster: passo 6, immagine 1 di 1
    • With the speedometer cable disconnected you will be able to pull the cluster out further for more working room.
    • Starting on the right side, begin disconnecting the items that attach to it.
    • First, you will pull out any light bulbs that plug in to the right hand side of the cluster. On a diesel W123 this will include the glow plug bulb and seatbelt bulb. Then unplug the spade connector for the power supply to the clock.
  7. Removing Mercedes W123 Instrument Cluster: passo 7, immagine 1 di 2 Removing Mercedes W123 Instrument Cluster: passo 7, immagine 2 di 2
    • Next, unplug the two small plugs near the middle of the cluster.
  8. Removing Mercedes W123 Instrument Cluster: passo 8, immagine 1 di 1
    • Next, use a 10mm wrench to unscrew the oil line from the oil gauge.
    • Lastly, unplug the large round plug on the far left of the cluster, down and to the left of the oil gauge fitting.
  9. Removing Mercedes W123 Instrument Cluster: passo 9, immagine 1 di 1
    • With everything disconnected you can now remove the cluster, carefully working it up and out past the steering wheel.
  10. Removing Mercedes W123 Instrument Cluster: passo 10, immagine 1 di 1
    • With the cluster removed on this car, let's take a second to identify some of the connections:
    • Speedometer cable
    • Oil line fitting
    • Small plugs for cluster accessories and lighting
    • Large primary plug
    • Not pictured are the wires and bulbs for the glow plug and seat belt light, and the spade plug for the clock. Keep track of which bulb went in which socket - the wires will be different colors. On this car the wire for the seat belt light was green and the glow plug bulb wire was blue.
  11. Removing Mercedes W123 Instrument Cluster: passo 11, immagine 1 di 2 Removing Mercedes W123 Instrument Cluster: passo 11, immagine 2 di 2
    • You can now take the cluster to your work bench to undertake whatever job you removed it for.
    • Let's review the components, both front and back:
    • Oil pressure gauge, gas gauge, and engine temperature gauge
    • Speedometer, odometer and trip odometer
    • Tachometer and clock
  12. Removing Mercedes W123 Instrument Cluster: passo 12, immagine 1 di 1
    • And a bit more detail about the components on the back of the cluster:
    • Light bulb sockets (some are used, others are blanked out)
    • Speedometer cable connection
    • Rheostat (dimmer) control
    • Oil line connection
    • Clock spade connector (note +12v symbol, this is the constant 12v supply that can damage your cluster if battery is not disconnected)
    • Large primary cluster pins
    • Accessory plugs
Conclusione
Altre 50 persone hanno completato questa guida.
Nicolas Siemsen
Membro da: 12/06/13
39.010 Reputazione
79 Guide realizzate
Master Techs Membro di Master Techs
Community
322 Membri
2.521 Guide realizzate
14 Commenti
Any chance you can tell us what color of wires goes on each of the 15 pins from the large primary plug (Cluster pins) or even show a picture of where it all goes? Some of my wires got mixed up and it's really hard to tell which wires goes to what pins...
brandon - Replica
FYI I have a 85' CD300 if that helps. ;-)
brandon -
Hi, here is a link to a picture of the pin out diagram for the 15 pin plug behind the cluster.
http://www.benzworld.org/forums/attachme...
Nicolas Siemsen -
Hi all, I am looking for Mercedes Benz W123 speedometer part no. 1235423601 0085425606
Any idea where I can find a store or supplier providing genuine new parts, thanks
Jesmond Mifsud - Replica
Does it matter what direction the accessory plug on the speedometer is plugged in? It seems to go on both ways and I'm not sure if I am installing it right!
fixitsteve - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 56
Ultimi 30 Giorni: 347
Tutti i Tempi: 48,762
