Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Componenti & Strumenti
Introduzione
After you remove the back cover, you can get to any part of your RoadMate.
Parti
Nessuna parte specificata.
  1. Remove the four rubber caps from the back by using the Philips #00 screwdriver to pull them from the back. Remove the four rubber caps from the back by using the Philips #00 screwdriver to pull them from the back.
    • Remove the four rubber caps from the back by using the Philips #00 screwdriver to pull them from the back.
  2. Remove the four screws holding the cover in place by using the Phillips #00 screwdriver.
    • Remove the four screws holding the cover in place by using the Phillips #00 screwdriver.
  3. Remove the back cover from the device by separating the back cover along its seam. Slowly lift the cover, the speaker is screwed onto the back cover and is connected onto the circuit board.
    • Remove the back cover from the device by separating the back cover along its seam.
    • Slowly lift the cover, the speaker is screwed onto the back cover and is connected onto the circuit board.
  4. Pull the speaker cord, horizontally, by its base, away from the motherboard. When reassembling, make sure that you plug the terminal in the same way.  The black wire should be on the side farthest from the battery.
    • Pull the speaker cord, horizontally, by its base, away from the motherboard.
    • When reassembling, make sure that you plug the terminal in the same way. The black wire should be on the side farthest from the battery.
Conclusione
Altre 2 persone hanno completato questa guida.
Ross Light
Membro da: 12/04/2010
175 Reputazione
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 3,314
