Salta al contenuto principale
Removing Lenovo Thinkpad T61p RAM
Cosa ti serve
  1. Removing Lenovo Thinkpad T61p RAM, RAM: passo 1, immagine 1 di 2 Removing Lenovo Thinkpad T61p RAM, RAM: passo 1, immagine 2 di 2
    • Place the laptop on a fat surface with the underside facing up
    • Remove the 4 Philips head screws.
    • Turn the computer over and open the display
    • Grasping each side of the palm rest, gently lift it off and rotate toward the front of the laptop
    • The palm rest will be connected to the main board by a ribbon cable
  2. Removing Lenovo Thinkpad T61p RAM: passo 2, immagine 1 di 1
    • Disconnect the touchpad ribbon cable
    • This step is recommended in the service manual however it is possible to remove the RAM without discoinnecting the touchpad cable
  3. Removing Lenovo Thinkpad T61p RAM: passo 3, immagine 1 di 1
    • Locate the RAM modules
    • Gently press the metal tabs outwards to release the top RAM module and remove it from the laptop
    • With the top RAM module removed you can release the lower RAM module in the same manner.
Conclusione
Altre 5 persone hanno completato questa guida.
Glac1er
Membro da: 05/25/13
180 Reputazione
1 Guida realizzata
Glac1er Membro di Glac1er
Community
1 Membro
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 11
Tutti i Tempi: 9,946
