Salta al contenuto principale
Removing Infinitive Power Bank 20000 mAh AST-MP566 Case
    • The internal assembly is held in the case by the back plate, affixed by snaps running along the middle and lightweight glue. Be careful not to insert a flathead screwdriver deep into the top middle of the back plate as it can reach an unprotected spot on the internal battery.
    Chiedi a FixBot
    Aggiungi Commento
    • The back plate can be removed by gently and persistently prying at any loose spot on the edge and working one’s way around, revealing a protective wall at the back of the internal assembly blocking most of the battery surface immediately behind.
    Chiedi a FixBot
    Aggiungi Commento
    • This procedure can then be repeated for the front plate, to remove the internal assembly, once the back plate is no longer holding it in place.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Karl Semich
Membro da: 12/01/23
100 Reputazione
Una guida realizzata
0Commenti sulla guida
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 0
Ultimi 7 giorni: 3
Ultimi 30 giorni: 20
Tutti i Tempi: 84
