Salta al contenuto principale
Introduzione
This guide will show you how to remove the CPU Cooler on your HP Compaq dx2000MT.
  1. Turn off your computer and remove the power cable by pulling it straight out of its socket.
    • Turn off your computer and remove the power cable by pulling it straight out of its socket.
  2. Remove the two Phillips #2 screws that secure the case door to the device. Remove the two Phillips #2 screws that secure the case door to the device.
    • Remove the two Phillips #2 screws that secure the case door to the device.
  3. Remove the side case door by pushing towards the rear of the device with your hand. This may take considerable force so keep pushing! Once you slide the door back, remove it by pulling it outwards from the device.
    • Remove the side case door by pushing towards the rear of the device with your hand.
    • This may take considerable force so keep pushing!
    • Once you slide the door back, remove it by pulling it outwards from the device.
  4. Remove the side case door by pushing towards the rear of the device with your hand. Once again, this may take considerable force. Once you slide the door back, remove it by pulling it outwards from the device.
    • Once again, this may take considerable force.
  5. Remove the 3 pin power connector by pulling it towards the side of the device. Remove the 3 pin power connector by pulling it towards the side of the device.
    • Remove the 3 pin power connector by pulling it towards the side of the device.
  6. Unscrew the 4 Torx T15 screws holding the CPU Cooler in place. Make sure to hold your cpu cooler when removing the screws. You don't want it to fall!
    • Unscrew the 4 Torx T15 screws holding the CPU Cooler in place.
    • Make sure to hold your cpu cooler when removing the screws. You don't want it to fall!
  7. Remove the cpu cooler by pulling out towards the side of the device. Make sure you do not touch where the cpu cooler makes contact with the processor! You could contaminate the layer of thermal paste that separates these components.
    • Remove the cpu cooler by pulling out towards the side of the device.
    • Make sure you do not touch where the cpu cooler makes contact with the processor! You could contaminate the layer of thermal paste that separates these components.
    • When replacing your cpu cooler, make sure you clean the processor contact area on the cooler and processor with isopropyl rubbing alcohol.
Conclusione
Altre 2 persone hanno completato questa guida.
Logan Pace
Membro da: 12/10/2011
2.020 Reputazione
9 Guide realizzate
Cal Poly, Team 17-16, Regan Fall 2011 Membro di Cal Poly, Team 17-16, Regan Fall 2011
CPSU-REGAN-F11S17G16
4 Membri
17 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 40
Tutti i Tempi: 4,248
