Salta al contenuto principale
Removing HP Compaq dx2000MT CPU Cooler
Cosa ti serve
  1. Removing HP Compaq dx2000MT CPU Cooler, Removing the HP Compaq dx2000MT Case Doors: passo 1, immagine 1 di 1
    • Turn off your computer and remove the power cable by pulling it straight out of its socket.
  2. Removing HP Compaq dx2000MT CPU Cooler: passo 2, immagine 1 di 2 Removing HP Compaq dx2000MT CPU Cooler: passo 2, immagine 2 di 2
    • Remove the two Phillips #2 screws that secure the case door to the device.
  3. Removing HP Compaq dx2000MT CPU Cooler: passo 3, immagine 1 di 3 Removing HP Compaq dx2000MT CPU Cooler: passo 3, immagine 2 di 3 Removing HP Compaq dx2000MT CPU Cooler: passo 3, immagine 3 di 3
    • Remove the side case door by pushing towards the rear of the device with your hand.
    • This may take considerable force so keep pushing!
    • Once you slide the door back, remove it by pulling it outwards from the device.
  4. Removing HP Compaq dx2000MT CPU Cooler: passo 4, immagine 1 di 3 Removing HP Compaq dx2000MT CPU Cooler: passo 4, immagine 2 di 3 Removing HP Compaq dx2000MT CPU Cooler: passo 4, immagine 3 di 3
    • Once again, this may take considerable force.
  5. Removing HP Compaq dx2000MT CPU Cooler, Removing HP Compaq dx2000MT CPU Cooler: passo 5, immagine 1 di 2 Removing HP Compaq dx2000MT CPU Cooler, Removing HP Compaq dx2000MT CPU Cooler: passo 5, immagine 2 di 2
    • Remove the 3 pin power connector by pulling it towards the side of the device.
  6. Removing HP Compaq dx2000MT CPU Cooler: passo 6, immagine 1 di 2 Removing HP Compaq dx2000MT CPU Cooler: passo 6, immagine 2 di 2
    • Unscrew the 4 Torx T15 screws holding the CPU Cooler in place.
    • Make sure to hold your cpu cooler when removing the screws. You don't want it to fall!
  7. Removing HP Compaq dx2000MT CPU Cooler: passo 7, immagine 1 di 2 Removing HP Compaq dx2000MT CPU Cooler: passo 7, immagine 2 di 2
    • Remove the cpu cooler by pulling out towards the side of the device.
    • Make sure you do not touch where the cpu cooler makes contact with the processor! You could contaminate the layer of thermal paste that separates these components.
    • When replacing your cpu cooler, make sure you clean the processor contact area on the cooler and processor with isopropyl rubbing alcohol.
Conclusione
Altre 2 persone hanno completato questa guida.
Logan Pace
Membro da: 10/12/11
2.278 Reputazione
9 Guide realizzate
Cal Poly, Team 17-16, Regan Fall 2011 Membro di Cal Poly, Team 17-16, Regan Fall 2011
CPSU-REGAN-F11S17G16
4 Membri
17 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 5,514
