Flip the Delphi MyFi XM2GO Device on its back to start the cover-removal process.
  • Flip the Delphi MyFi XM2GO Device on its back to start the cover-removal process.
  • The back cover is the access point for the user-removable battery. Removing the back cover also gives the user access to the hard-reset button.
Aggiungi Commento
Locate the large button on the top back of the device. This button is used to release the latch holding the sliding back cover in place.
  • Locate the large button on the top back of the device. This button is used to release the latch holding the sliding back cover in place.
  • Press this button at the top while making a firm grip on the battery cover.
  • As the button is pressed, move the cover towards the bottom of the device while applying moderate pressure to the cover.
  • Be careful to not press down too hard on the battery cover as it is made of plastic.
  • The battery removal tab may pop up during the cover removal process.
Aggiungi Commento
  • After the cover is removed, the white Lithium Ion battery is visible.
Aggiungi Commento
Conclusione
Scott Byer
Membro da: 09/03/2012
61 Reputazione
5 Guide realizzate
Clemson, Team 1-2, Benson Spring 2012 Membro di Clemson, Team 1-2, Benson Spring 2012
CLEM-BENSON-S12S1G2
3 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,256
