Salta al contenuto principale
Removing Dell Inspiron 1150 RAM
Cosa ti serve
  1. Removing Dell Inspiron 1150 RAM, Removing Dell Inspiron 1150 RAM: passo 1, immagine 1 di 1
    • Turn the laptop so that the bottom is facing up.
    • Locate the panel that has an M on it and two air vents.
  2. Removing Dell Inspiron 1150 RAM: passo 2, immagine 1 di 2 Removing Dell Inspiron 1150 RAM: passo 2, immagine 2 di 2
    • Take the screw driver and carefully unscrew the screw that is located above the M in order to remove the panel.
    • Put this screw in a bag or easily identifiable place.
    • Remove the panel.
  3. Removing Dell Inspiron 1150 RAM: passo 3, immagine 1 di 3 Removing Dell Inspiron 1150 RAM: passo 3, immagine 2 di 3 Removing Dell Inspiron 1150 RAM: passo 3, immagine 3 di 3
    • After removing the panel, you will see two memory modules.
    • Locate the four spring clips that are holding the memory modules in place.
    • Place your thumb on each of the two spring clips for each memory module and push outward until the memory module pops up.
    • Gently raise the memory module and lift it out of its socket.
Conclusione
Cal Poly, Team 16-2, Maness Spring 2010 Membro di Cal Poly, Team 16-2, Maness Spring 2010
CPSU-MANESS-S10S16G2
4 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 7
Tutti i Tempi: 5,825
