Salta al contenuto principale
Removing Dell Inspiron 1150 Mini Wireless PCI Card
Cosa ti serve
  1. Removing Dell Inspiron 1150 Mini Wireless PCI Card, Mini Wireless PCI Card: passo 1, immagine 1 di 3 Removing Dell Inspiron 1150 Mini Wireless PCI Card, Mini Wireless PCI Card: passo 1, immagine 2 di 3 Removing Dell Inspiron 1150 Mini Wireless PCI Card, Mini Wireless PCI Card: passo 1, immagine 3 di 3
    • Turn the laptop upside down and locate the panel labeled C.
    • Unscrew the single screw holding the cover in place.
    • Lift up the cover and remove it to expose the Wireless MiniPCI Card.
  2. Removing Dell Inspiron 1150 Mini Wireless PCI Card: passo 2, immagine 1 di 2 Removing Dell Inspiron 1150 Mini Wireless PCI Card: passo 2, immagine 2 di 2
    • Using a plastic spudger or similar, gently pry the grey and black wires off.
    • The grey and black wires are the antenna wires so be careful not to damage them
    • Gently pull the retaining clips away from the board so that the board pops up.
  3. Removing Dell Inspiron 1150 Mini Wireless PCI Card: passo 3, immagine 1 di 1
    • Lift the board up and out of the mini PCI slot at an angle of about 35 - 45 degrees
Conclusione
Teja
Membro da: 04/27/10
98 Reputazione
3 Guide realizzate
Cal Poly, Team 16-2, Maness Spring 2010 Membro di Cal Poly, Team 16-2, Maness Spring 2010
CPSU-MANESS-S10S16G2
4 Membri
9 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 11
Tutti i Tempi: 5,901
