Salta al contenuto principale
Introduzione
If you’re repairing any part of the computer, it is always important to remove the battery.
  1. Place the laptop upside down on a clean, flat surface. Locate the battery release button with the padlock symbol above it. Slide the battery release button towards the padlock symbol and hold it there.  Note that the button is spring loaded and will return if released.
    • Place the laptop upside down on a clean, flat surface.
    • Locate the battery release button with the padlock symbol above it.
    • Slide the battery release button towards the padlock symbol and hold it there. Note that the button is spring loaded and will return if released.
    • The battery is now released from the battery compartment.
    • Gently remove the battery from the side of the laptop.
  2. Batterie per PC portatili
    Una soluzione semplice per un grande aumento di potenza.
    Acquista ora
    Acquista ora
Linea Traguardo
Altre 6 persone hanno completato questa guida.
Teja
Membro da: 27/04/2010
98 Reputazione
3 Guide realizzate
Cal Poly, Team 16-2, Maness Spring 2010 Membro di Cal Poly, Team 16-2, Maness Spring 2010
CPSU-MANESS-S10S16G2
4 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 13
Tutti i Tempi: 10,493
