Salta al contenuto principale
Removing Creative Zen Vision W Back Cover
Cosa ti serve
  1. Removing Creative Zen Vision W Back Cover, Battery Removal: passo 1, immagine 1 di 3 Removing Creative Zen Vision W Back Cover, Battery Removal: passo 1, immagine 2 di 3 Removing Creative Zen Vision W Back Cover, Battery Removal: passo 1, immagine 3 di 3
    • Push the black button and slide the battery casing to the left simultaneously, until the battery is completely separated from the device.
  2. Removing Creative Zen Vision W Back Cover, Back Cover: passo 2, immagine 1 di 1
    • Remove the 2 screws (3.5 mm) on the Compact Flash insert, located on the left hand side, with a Phillips #000 screwdriver.
  3. Removing Creative Zen Vision W Back Cover: passo 3, immagine 1 di 2 Removing Creative Zen Vision W Back Cover: passo 3, immagine 2 di 2
    • Remove the 5 screws (5.5 mm), circled in red, using a Phillips #0. Use a flashlight if necessary.
    • Peel off the sticker that says "Creative warranty void if broken" and remove the screw (5.5 mm) underneath with a Phillips #0.
    • Be careful, some of the screws are difficult to see and can be easily stripped.
  4. Removing Creative Zen Vision W Back Cover: passo 4, immagine 1 di 3 Removing Creative Zen Vision W Back Cover: passo 4, immagine 2 di 3 Removing Creative Zen Vision W Back Cover: passo 4, immagine 3 di 3
    • Carefully pull the back cover off of the rest of the device.
    • The volume control buttons and power slider may fall off when removing the cover, do not lose these small pieces.
    • The USB input cover on the bottom of the device may also fall off.
Conclusione
Gabriele Pregadio
Membro da: 04/17/13
1 Reputazione
2 Guide realizzate
Cal Poly, Team 17-2, Regan Spring 2013 Membro di Cal Poly, Team 17-2, Regan Spring 2013
CPSU-REGAN-S13S17G2
4 Membri
8 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 840
