Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Parti
Nessuna parte specificata.
  1. Flip the keyboard upside down so the bottom is angled towards you.
    • Flip the keyboard upside down so the bottom is angled towards you.
  2. Use a #2 Phillips screwdriver to remove the twenty-seven 12 mm screws from the dark gray bottom panel.
    • Use a #2 Phillips screwdriver to remove the twenty-seven 12 mm screws from the dark gray bottom panel.
  3. Remove the bottom panel by lifting the bottom panel up and outward from yourself.
    • Remove the bottom panel by lifting the bottom panel up and outward from yourself.
  4. Flip the entire keyboard so the keys face up, and be careful not to let the bottom drop. Flip the top half of the keyboard and set onto the bottom half with the internal parts facing up.
    • Flip the entire keyboard so the keys face up, and be careful not to let the bottom drop.
    • Flip the top half of the keyboard and set onto the bottom half with the internal parts facing up.
Conclusione
Jimmy Winne
Membro da: 04/10/2012
494 Reputazione
6 Guide realizzate
Cal Poly, Team 9-16, Amido Fall 2012 Membro di Cal Poly, Team 9-16, Amido Fall 2012
CPSU-AMIDO-F12S9G16
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 27
Tutti i Tempi: 1,652
