Salta al contenuto principale
Removing Canon PowerShot A550 Front and Back Covers
Cosa ti serve
  1. Removing Canon PowerShot A550 Front and Back Covers, Front and Back Covers: passo 1, immagine 1 di 3 Removing Canon PowerShot A550 Front and Back Covers, Front and Back Covers: passo 1, immagine 2 di 3 Removing Canon PowerShot A550 Front and Back Covers, Front and Back Covers: passo 1, immagine 3 di 3
    • Unscrew a total of 6 4.45 mm phillips head screws using a #00 phillips head screwdriver.
    • There are 2 screws on the left side (when looking at the front of the camera).
    • There are 3 screws on the bottom
    • There is 1 screw on the right side
  2. Removing Canon PowerShot A550 Front and Back Covers: passo 2, immagine 1 di 1
    • Turn to the bottom of the camera.
    • Open the memory card cover by sliding the "CARD/BATT." button up, and then pulling the cover to the left.
  3. Removing Canon PowerShot A550 Front and Back Covers: passo 3, immagine 1 di 1
    • This is what the SD card/battery compartment looks like when opened.
    • Remove one 4.45mm phillips head screw from the SD card/battery compartment using a #00 phillips head screwdriver.
  4. Removing Canon PowerShot A550 Front and Back Covers: passo 4, immagine 1 di 2 Removing Canon PowerShot A550 Front and Back Covers: passo 4, immagine 2 di 2
    • Gently remove the front cover away from the camera body.
    • Tip: Start by loosening the teeth on the left side of the camera next to the battery compartment.
  5. Removing Canon PowerShot A550 Front and Back Covers: passo 5, immagine 1 di 1
    • The camera should look like this once the front cover is removed.
  6. Removing Canon PowerShot A550 Front and Back Covers: passo 6, immagine 1 di 3 Removing Canon PowerShot A550 Front and Back Covers: passo 6, immagine 2 di 3 Removing Canon PowerShot A550 Front and Back Covers: passo 6, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Start from the battery compartment and remove the back cover.
    • Caution: Do not tug on the back cover after it is removed. This could tear the ribbon attaching the back cover to the camera body.
    • Remove the connecting ribbon from the body of the camera using a pair of tweezers.
  7. Removing Canon PowerShot A550 Front and Back Covers: passo 7, immagine 1 di 1
    • Once the ribbon connecting the back cover is removed, the back of the camera body should look like this.
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 8-6, Regan Spring 2011 Membro di Cal Poly, Team 8-6, Regan Spring 2011
CPSU-REGAN-S11S8G6
4 Membri
22 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 22
Tutti i Tempi: 4,336
