Salta al contenuto principale
Removing Audio Technica ATH-AD500 Foam Disks
Cosa ti serve
  1. Removing Audio Technica ATH-AD500 Foam Disks, Speaker Assembly: passo 1, immagine 1 di 1
    • Remove the ear pads by peeling them away from the grill.
  2. Removing Audio Technica ATH-AD500 Foam Disks: passo 2, immagine 1 di 1
    • Remove all four 1cm screws on the inside of the headphone using a #1 Phillips head.
  3. Removing Audio Technica ATH-AD500 Foam Disks: passo 3, immagine 1 di 1
    • Remove the speaker from the grill by pulling it out.
    • Remove the speaker carefully so you do not rip the wires out.
  4. Removing Audio Technica ATH-AD500 Foam Disks, Foam Disks: passo 4, immagine 1 di 2 Removing Audio Technica ATH-AD500 Foam Disks, Foam Disks: passo 4, immagine 2 di 2
    • Remove the foam disk from the grill by peeling it away from the grill.
    • During reassembly, make sure that the speaker is angled into your ear canal.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 17-19, Forte Winter 2013 Membro di Cal Poly, Team 17-19, Forte Winter 2013
CPSU-FORTE-W13S17G19
6 Membri
17 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 20
Tutti i Tempi: 2,090
