Salta al contenuto principale
Removing factory feet from a Mac Laptop (Non-Retina)
Cosa ti serve
  1. Removing factory feet from a Mac Laptop (Non-Retina), Remove the bottom cover: passo 1, immagine 1 di 2 Removing factory feet from a Mac Laptop (Non-Retina), Remove the bottom cover: passo 1, immagine 2 di 2
    • I am using a 2011 13" MacBook Pro. Most machines are similar, but variations may exist.
    • If possible, disconnect the battery to protect your components once the bottom is removed.
    • Remove the bottom cover of your MacBook with the guide for your specific system.
  2. Removing factory feet from a Mac Laptop (Non-Retina), Removing failed feet: passo 2, immagine 1 di 3 Removing factory feet from a Mac Laptop (Non-Retina), Removing failed feet: passo 2, immagine 2 di 3 Removing factory feet from a Mac Laptop (Non-Retina), Removing failed feet: passo 2, immagine 3 di 3
    • Before removing the good feet, remove the failed feet first. These may come off without disassembly if they have fully failed.
    • After removing the damaged feet, remove the intact feet. Follow the disassembly guide for your specific Mac.
  3. Removing factory feet from a Mac Laptop (Non-Retina), (Full set replacement only) Removing intact feet: passo 3, immagine 1 di 3 Removing factory feet from a Mac Laptop (Non-Retina), (Full set replacement only) Removing intact feet: passo 3, immagine 2 di 3 Removing factory feet from a Mac Laptop (Non-Retina), (Full set replacement only) Removing intact feet: passo 3, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    iFixit Opening Picks (Set of 6)
    Compra
    • To remove the intact feet, score the internal plug. Once scored, remove the plug with a guitar pick.
    • After removing the inner plug, push the foot out with a spudger or screwdriver.
  4. Removing factory feet from a Mac Laptop (Non-Retina), Install the new feet: passo 4, immagine 1 di 2 Removing factory feet from a Mac Laptop (Non-Retina), Install the new feet: passo 4, immagine 2 di 2
    Adhesive Cleanup Kit (Set of 12)
    Compra
    • If the adhesive ring remains, remove it first. Clean the chassis with denatured alcohol or adhesive cleaner.
    • After removing the old feet, install the new set onto the bottom cover.
    • Re-install the cover on the computer.
Linea Traguardo
Altre 4 persone hanno completato questa guida.
Nick
Membro da: 11/10/09
88.987 Reputazione
50 Guide realizzate
Master Techs Membro di Master Techs
Community
321 Membri
1.468 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 81
Tutti i Tempi: 4,409
