Salta al contenuto principale
Introduzione
This guide shows how to separate the GameCube's optical drive assembly from the motherboard.
  1. Remove Nintendo GameCube Optical Drive Assembly, Top Case: passo 1, immagine 1 di 3 Remove Nintendo GameCube Optical Drive Assembly, Top Case: passo 1, immagine 2 di 3 Remove Nintendo GameCube Optical Drive Assembly, Top Case: passo 1, immagine 3 di 3
    • Turn over the Gamecube so that the bottom side is facing up.
    • Locate the four screws (circled in red) on each corner of the device. Then, use a 4.5 mm Gamebit screwdriver to remove all four screws.
  2. Remove Nintendo GameCube Optical Drive Assembly: passo 2, immagine 1 di 3 Remove Nintendo GameCube Optical Drive Assembly: passo 2, immagine 2 di 3 Remove Nintendo GameCube Optical Drive Assembly: passo 2, immagine 3 di 3
    • With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half. Then place the inside of the unit facing up.
  3. Remove Nintendo GameCube Optical Drive Assembly, Optical Drive Assembly: passo 3, immagine 1 di 2 Remove Nintendo GameCube Optical Drive Assembly, Optical Drive Assembly: passo 3, immagine 2 di 2
    • The left side of the unit contains the cooling fan and its housing. Carefully remove the two (2) screws attaching the cooling fan housing to the unit.
    • Do not detach the red and black cooling fan wire from the main unit.(red/black wire)
  4. Remove Nintendo GameCube Optical Drive Assembly: passo 4, immagine 1 di 2 Remove Nintendo GameCube Optical Drive Assembly: passo 4, immagine 2 di 2
    • Remove the four (4) Phillips #1 screws retaining the ground springs
    • Carefully remove the ground springs from the main unit as shown in the second photograph.
  5. Remove Nintendo GameCube Optical Drive Assembly: passo 5, immagine 1 di 2 Remove Nintendo GameCube Optical Drive Assembly: passo 5, immagine 2 di 2
    • The optical drive is secured to a metal plate.
    • Using a Phillips #2 screwdriver, unscrew the twelve (12) screws that are around the outer edge of the optical drive (circled in red).
  6. Remove Nintendo GameCube Optical Drive Assembly: passo 6, immagine 1 di 3 Remove Nintendo GameCube Optical Drive Assembly: passo 6, immagine 2 di 3 Remove Nintendo GameCube Optical Drive Assembly: passo 6, immagine 3 di 3
    • Carefully separate the optical drive assembly from the rest of the GameCube unit.
    • The optical drive assembly is secured to the motherboard underneath by a slot; some force may be required to carefully free the assembly.
    • The metal plate and the actual optical drive will remain attached (picture 3).
Conclusione
dcarlin
Membro da: 05/11/2009
295 Reputazione
4 Guide realizzate
Cal Poly, Team 6-2, Maness Fall 2009 Membro di Cal Poly, Team 6-2, Maness Fall 2009
CPSU-MANESS-F09S6G2
4 Membri
37 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 4,322
