Salta al contenuto principale
Remove Jura Brew unit
  1. Remove Jura Brew unit, Jura Impressa Type C E F opening procedure: passo 1, immagine 1 di 1
    • The instructions are suitable for nearly every model of Jura and similar ones e.g. AEG and Krups.
    • Unplug!
    • Remove the water reservoir.
  2. Remove Jura Brew unit: passo 2, immagine 1 di 3 Remove Jura Brew unit: passo 2, immagine 2 di 3 Remove Jura Brew unit: passo 2, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    • On the rear side is an obstacle: four "oval head screws" looking like rivets. You can remove them using a special oval drive bit. They are sold at iFixit with the tool kits as well as some Jura suppliers or somewhere in the internet. Jura wants to keep us out of our own machines!
    • Using an oval head bit you can screw them out. If you haven´t got one you can carefully use pliers. It is a good idea to later change the screws for normal ones.
    • You can even create your own specialty tool
    • Beneath both top side covers are two Torx T15 screws. Remove those. Now lift off the whole top cover. Sometimes it jams and you have to use a bit of force.
    • The side covers must be pushed backwards by about 1 cm. Sometimes this is a little bit difficult to move. If necessary, wedge a plastic opening tool into the gap between the side covers and the front panel. The rear cover can be easily removed.
  3. Remove Jura Brew unit, Remove Jura Brew unit: passo 3, immagine 1 di 1
    • Slide the coffee funnel up and lift it out. It often sits very tight and you have to pull hard until it becomes free.
    • It is often firmly locked in place, it loosens if you wiggle it back and forth a little. It can also be fastened with a screw.
  4. Remove Jura Brew unit: passo 4, immagine 1 di 2 Remove Jura Brew unit: passo 4, immagine 2 di 2
    • Remove the Torx T15 screw from the water inlet.
    • Lift the water inlet and bend it to the side. The hose can remain connected.
  5. Remove Jura Brew unit: passo 5, immagine 1 di 2 Remove Jura Brew unit: passo 5, immagine 2 di 2
    • Pull out the clamp on the pressure hose between the steam valve and the brew unit.
    • Remove the pressure hose.
  6. Remove Jura Brew unit: passo 6, immagine 1 di 2 Remove Jura Brew unit: passo 6, immagine 2 di 2
    • The brew unit is mounted from the motor side with two Torx T20 screws to the left and right of the motor connection, these are located deep on the inside.
    • Remove the right screw
    • Remove the left screw
  7. Remove Jura Brew unit: passo 7, immagine 1 di 2 Remove Jura Brew unit: passo 7, immagine 2 di 2
    • The brew unit moves up and down in a slide driven by an elongated rack. There are four Torx T10 screws on the slide. The top left screw must remain attached.
    • The screw on the top left must remain.
    • Remove the screw on the bottom left
    • remove the screw on the bottom right and the one in the middle right
  8. Remove Jura Brew unit: passo 8, immagine 1 di 1
    • Now the brew unitis free. Tilt it to the bottom but pay attention to the pressure hose. It must be led through an opening. Then push the brew group slightly downward to lift it out of the unit.
    • For further disassembly of the brew unit use this manual JURA Brewgroup Disassembly
Conclusione
Reverse the steps to reassemble your device.
(Note: if necessary, the oval screws can also be unscrewed with combination pliers and then replaced with others)
Altre 13 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
de en
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
VauWeh
Membro da: 10/19/15
326.270 Reputazione
310 Guide realizzate
5Commenti sulla guida
What position should the piston be in when reassembling? Mine seems to bottom out and then the motor makes a horrible grinding noise. This is after reassembly.
Joakim - Rispondi Condividi
The position is not very important. The distance between the big wheel and top may be about 4 cm. My guess is, that the position of your screws is wrong. Look at the pictures in step 7: the blue one is a machine screw and must not be removed. On the left side remains one screw (yellow) beyond the blue. On the right side are two screws (red), one near of the drainage valve and one above. In the upper region of the brewing unit are two empty holes, maybe you filled them?
VauWeh - Rispondi Condividi
Another possibilty is a wrong position of the lower piston. Did you test the function of the brewing unit by turning the white gear a complete cycle? Does it move smoothly?
bonjour j’ai bien nettoyé ma jura Impressa-F50-Pumpe e75 le groupe fonctionne parfaitement à la main mais se bloque en bas et en haut pendant la mise en place de la machine , pourtant j’ai changé le moteur et l’encodeur, que peut il se passer merci pour votre réponse cordialement
lyard - Rispondi Condividi
Dans ce cas, je devinerais l'encodeur. Mais s'il a déjà été échangé, est-ce peut-être l'électronique? C'est dommage.
VauWeh - Condividi
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 23
Ultimi 7 Giorni: 251
Ultimi 30 Giorni: 963
Tutti i Tempi: 64,085
