Salta al contenuto principale
Removal/Replacement of Dell Inspiron E1705 Hard Drive
Cosa ti serve
  1. Removal/Replacement of Dell Inspiron E1705 Hard Drive, Battery: passo 1, immagine 1 di 1
    • Make sure that the computer is turned off and is disconnected from external power source.
    • Turn it upside down and locate the battery release switch.
  2. Removal/Replacement of Dell Inspiron E1705 Hard Drive: passo 2, immagine 1 di 2 Removal/Replacement of Dell Inspiron E1705 Hard Drive: passo 2, immagine 2 di 2
    • While holding the switch in the open position, lift out the battery.
    • If you plan to work on any internal laptop components, press and hold the power button for 5 seconds. This will dissipate any residual charge on the motherboard to prevent electrical shock when you begin to handle it.
  3. Removal/Replacement of Dell Inspiron E1705 Hard Drive, Hard Drive: passo 3, immagine 1 di 2 Removal/Replacement of Dell Inspiron E1705 Hard Drive, Hard Drive: passo 3, immagine 2 di 2
    • Remove the two Phillips #1 screws on the left side of the computer, just above the battery compartment.
    • These screws hold the hard drive tray into the hard drive compartment.
  4. Removal/Replacement of Dell Inspiron E1705 Hard Drive: passo 4, immagine 1 di 1
    • Slide the hard drive tray out of the hard drive compartment.
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 22-5, Maness Fall 2010 Membro di Cal Poly, Team 22-5, Maness Fall 2010
CPSU-MANESS-F10S22G5
4 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 28
Tutti i Tempi: 20,320
