Introduzione
Two tools required for the completion of this task include a PH1 screwdriver, and a prying tool.
All screws on this device are 10mm (0.393 in).
Cosa ti serve
Place the prying tool in between the hair straightener and the aligning cap.
Push forwards on the prying tool to pop off the aligning cap.
After the hair straightener is separated, use a Phillips #1 screwdriver to remove the two screws located on the lower half of the straightener.
Use the prying tool to remove the hinge cover.
Altre 2 persone hanno completato questa guida.
6 Commenti
is there a place where you can buy and replace the power cable, or the plug ?
the slip ring plug that is ..
part number would be helpful?
Howdy!
Turns out step 3 is really the only step you need to do. Remove the two screws that cover the swivel power connector. You don't need to mess with the hinge at all.
