Salta al contenuto principale
Aggiusta la tua roba
Diritto alla Riparazione
Store
Introduzione
Two tools required for the completion of this task include a PH1 screwdriver, and a prying tool.
All screws on this device are 10mm (0.393 in).
  1. Place the prying tool in between the hair straightener and the aligning cap. Push forwards on the prying tool to pop off the aligning cap.
    • Place the prying tool in between the hair straightener and the aligning cap.
    • Push forwards on the prying tool to pop off the aligning cap.
  2. Remove the screws with the Phillips #1 screwdriver located underneath the aligning cap, one on each side of the straightener. Use the prying tool to remove the aligning rods after the removal of the screws. Gently separate each half of the hair straightener.
    • Remove the screws with the Phillips #1 screwdriver located underneath the aligning cap, one on each side of the straightener.
    • Use the prying tool to remove the aligning rods after the removal of the screws.
    • Gently separate each half of the hair straightener.
    • The spring located in the middle of this mechanism may pop out and can get lost very easily. Try to separate the two components slowly.
  3. After the hair straightener is separated, use a Phillips #1 screwdriver to remove the two  screws  located on the lower half of the straightener. Use the prying tool to remove the hinge cover.
    • After the hair straightener is separated, use a Phillips #1 screwdriver to remove the two screws located on the lower half of the straightener.
    • Use the prying tool to remove the hinge cover.
  4. Pull upwards while pulling outwards to disconnect the wire from the housing. Pull upwards while pulling outwards to disconnect the wire from the housing.
    • Pull upwards while pulling outwards to disconnect the wire from the housing.
Conclusione
Benjamin Yohe
Membro da: 11/07/2018
255 Reputazione
2 Guide realizzate
IUPUI, Team S3-G3, Wilson Summer 2018 Membro di IUPUI, Team S3-G3, Wilson Summer 2018
IUPUI-WILSON-SU18S3G3
5 Membri
2 Guide realizzate
Excelente trabajo! Muchas gracias por la información!
Ronnetto - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 102
Tutti i Tempi: 1,459
