Salta al contenuto principale
Remington MB4040 Cover Assembly Replacement
Solo Prerequisita
Questa guida è destinata a essere usata solo come prerequisito per altre guide. Da sola è incompleta.
Cosa ti serve
  1. Remington MB4040 Cover Assembly Replacement, Remove Blade Assembly: passo 1, immagine 1 di 3 Remington MB4040 Cover Assembly Replacement, Remove Blade Assembly: passo 1, immagine 2 di 3 Remington MB4040 Cover Assembly Replacement, Remove Blade Assembly: passo 1, immagine 3 di 3
    • Press the black button below the blade to remove the blade.
  2. Remington MB4040 Cover Assembly Replacement, Remove Back Cover Hardware: passo 2, immagine 1 di 2 Remington MB4040 Cover Assembly Replacement, Remove Back Cover Hardware: passo 2, immagine 2 di 2
    • Place the device so the back of the product is facing up.
    • Remove the two 11.0 mm PH00 screws from the black plastic housing at the bottom of the device.
  3. Remington MB4040 Cover Assembly Replacement, Remove Front Cover Hardware: passo 3, immagine 1 di 3 Remington MB4040 Cover Assembly Replacement, Remove Front Cover Hardware: passo 3, immagine 2 di 3 Remington MB4040 Cover Assembly Replacement, Remove Front Cover Hardware: passo 3, immagine 3 di 3
    • Remove the chrome plated plastic piece by using the plastic opening tool to pry it from the housing assembly.
    • Remove the small clear plastic piece that covers the zoom wheel numbers.
  4. Remington MB4040 Cover Assembly Replacement, Front Cover (cont.): passo 4, immagine 1 di 2 Remington MB4040 Cover Assembly Replacement, Front Cover (cont.): passo 4, immagine 2 di 2
    • Remove the two 16.0 mm PH00 screws from the front cover.
    • Use the blue plastic opening tool to pry apart the two halves of the device.
  5. Remington MB4040 Cover Assembly Replacement, Blade Button Removal: passo 5, immagine 1 di 2 Remington MB4040 Cover Assembly Replacement, Blade Button Removal: passo 5, immagine 2 di 2
    • Remove the black blade button and the two 10.0 mm springs, which are sandwiched between the cover assembly halves.
    • The blade button is sandwiched between the halves and the two springs may fall out when the halves are separated.
Conclusione
USF Tampa, Team 1-5, Blackwell Winter 2015 Membro di USF Tampa, Team 1-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G5
3 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 18
Tutti i Tempi: 128
