Salta al contenuto principale
Refresh, Reset, Start-up repair from USB recovery media
Panoramica Video
  1. Refresh, Reset, Start-up repair from USB recovery media, Refresh, Reset, Start-up repair from USB recovery media: passo 1, immagine 1 di 3 Refresh, Reset, Start-up repair from USB recovery media, Refresh, Reset, Start-up repair from USB recovery media: passo 1, immagine 2 di 3 Refresh, Reset, Start-up repair from USB recovery media, Refresh, Reset, Start-up repair from USB recovery media: passo 1, immagine 3 di 3
    • - Make Surface turned off and plugged in.
    • - Insert the USB recovery drive into the USB port.
    • - Press and hold the Volume Down button, press the Power button in a short time.
    • - When the Surface logo appears, release the Volume button.
    • - Select the language and keyboard layout.
    Where do I get the USB from?
    Soto Jaime - Replica
  2. Refresh, Reset, Start-up repair from USB recovery media: passo 2, immagine 1 di 3 Refresh, Reset, Start-up repair from USB recovery media: passo 2, immagine 2 di 3 Refresh, Reset, Start-up repair from USB recovery media: passo 2, immagine 3 di 3
    • Now you are in the Advanced Startup Options menu. You can choose from:
    • - Refresh your PC
    • - Reset your PC
    • ...or from Advanced options menu:
    • - Start-up repair
    • - Command prompt
    I tried downloading recovery image but some error while extracting it into the usb. Please help.
    Raj Patil - Replica
Conclusione
Altre 8 persone hanno completato questa guida.
ZFix
Membro da: 12/09/13
191.368 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
321 Membri
1.464 Guide realizzate
3 Commenti
Hello.my surface rt is not working properly.The windows is on and off.What should i do?
Muzahar - Replica
Hello.My surface rt is not working properly.
The windows display is on and off. What should i do to prenvent it?
Muzahar - Replica
Hello!
RT is not working properly ! I have Surface RT arm and no eny possibility to come in to uefi even I press upp vol. and press on. The tablet will no start and will not to be able on for around 3 \4 minutes. The USB with the windows is it in but when I tray to start with vol down and press on not working like the video shwoing. :(
pigi01se - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 23
Tutti i Tempi: 5,595
