Salta al contenuto principale
Redmi Note 9 Pro - Reboots, Power On flex Replacement
Cosa ti serve
Panoramica Video
Xiaomi Redmi Note 9 Pro restarts - Power On flex replacement
  1. Redmi Note 9 Pro - Reboots, Power On flex Replacement, Back cover removal: passo 1, immagine 1 di 3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Back cover removal: passo 1, immagine 2 di 3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Back cover removal: passo 1, immagine 3 di 3
    • Warm up the device to soften the adhesive.
    • Use plastic tools and a little isopropyl alcohol to separate the back cover.
  2. Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard plastic cover removal.: passo 2, immagine 1 di 3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard plastic cover removal.: passo 2, immagine 2 di 3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard plastic cover removal.: passo 2, immagine 3 di 3
    • Remove the Phillips screws that secure the motherboard cover.
    • Use a plastic opening tool to remove the cover.
  3. Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard removal - part 1: passo 3, immagine 1 di 3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard removal - part 1: passo 3, immagine 2 di 3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard removal - part 1: passo 3, immagine 3 di 3
    • Lift up the flex connector to disconnect the battery.
    • Remove the main cameras.
    • Remove the SIM tray.
  4. Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard removal - part 2: passo 4, immagine 1 di 3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard removal - part 2: passo 4, immagine 2 di 3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Motherboard removal - part 2: passo 4, immagine 3 di 3
    • Disconnect all flex cables:
    • Fingerprint sensor flex cable
    • Screen flex cable
    • Main flex cable
    • Coaxial antenna cable
    • Remove the Phillips screws securing the motherboard to the middle frame
    • Remove the motherboard.
  5. Redmi Note 9 Pro - Reboots, Power On flex Replacement, Power on and volume buttons flex cable removal.: passo 5, immagine 1 di 3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Power on and volume buttons flex cable removal.: passo 5, immagine 2 di 3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Power on and volume buttons flex cable removal.: passo 5, immagine 3 di 3
    • Remove the Fingerprint sensor.
    • Remove the volume buttons plastic cap.
    • Use isopropyl alcohol to help remove the glued down flex cable.
  6. Redmi Note 9 Pro - Reboots, Power On flex Replacement, Power on and volume buttons flex cable removal: passo 6, immagine 1 di 3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Power on and volume buttons flex cable removal: passo 6, immagine 2 di 3 Redmi Note 9 Pro - Reboots, Power On flex Replacement, Power on and volume buttons flex cable removal: passo 6, immagine 3 di 3
    • Use playing cards to remove the flex cable.
Conclusione
Altre 6 persone hanno completato questa guida.
ZFix
Membro da: 12/09/13
194.637 Reputazione
330 Guide realizzate
Master Techs Membro di Master Techs
Community
326 Membri
1.376 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 32
Ultimi 30 Giorni: 136
Tutti i Tempi: 6,240
